Hi muneca16,
The engine mount and hesitation should not be related.
Hesitation are mostly due to misfiring and can be due to bad spark plugs or related components such as ignition coil, plug wires and distributor components.
Except fr the rear engine mount, the others are relatively easy to replace and would not be a problem if you are mechanically inclined with the correect tools.
SPONSORED LINKS
Monday, October 25th, 2010 AT 12:07 PM
