If it is the door/safety indicators lights that are not turning off, then the Multiplex control unit has a fault. If it is the alternator charge light that stays on brighter, then it is not a problem with the alternator circuit.
If the charge indicator light is not fully bright when ignition switch is turned on and becomes fully bright after disconnecting and grounding the circuit, the alternator is the cause of it. The voltage regulator circuit is bad.
Saturday, August 28th, 2010 AT 2:18 PM
