The pan gasket would most probably be hardened by now so should be replaced. You might have difficulty getting the gasket off the pan. Use some heat from bottom of oil pan onto where the gasket seats and you would have no problem peeling it off.
The balancer gear O-ring and oil seal should be replaced since you are there.
SPONSORED LINKS
helpful?Yes
Wednesday, December 4th, 2019 AT 8:40 PM
(Merged)
