1994 Honda Accord 4 cyl Front Wheel Drive Manual
i JUST CHANGED THE TEMPERATURE SNESOR THAT RUNS THE GUAGE ON MY DASH. SINCE, MY CAR RUNS TOO HOT AT SPEEDS OVER FORTY MPH AND WILL DO THE SAME WHEN SITTING IDLE. I HAVE CHANGED THE THERMOSTAT, THE MAIN COOLING FAN, THE COOLING FAN TEMPERATURE SENSOR SWITCH (BETWEEN THE ENGINE AND RADIATOR ON THE TOP HOSE, SHOULD I CHANGE THE OTHER, ON THE THERMOSTAT HOUSING?). I TRIED TO BLEED THE SYSTEM, BUT NOT SURE IF I HAVE DONE IT PROPERLY. ANY HELP WOULD BE GREATLY APPRECIATED.
SPONSORED LINKS
Sunday, May 2nd, 2010 AT 7:31 PM
