1999 Honda Accord Dies After Start
CDHR6
  • 7 POSTS
Sometimes when I start my car it starts but hten acts like it is going to die. We have replaced the plug wires and the fuel pump. Does anyone have any ideas?
Feb 22, 2007 at 2:26 AM
BRUCE HUNT
  • 3,754 POSTS
Check the EGR valve and check the PCV valve. What is the idle speed that it wants to die at?
Feb 19, 2017 at 6:28 AM
CDHR6
  • 7 POSTS
Where are those valves located at? It seems to act this way right after you crank it and take your hand off the key. It is like it cranks at a high idle and then idles really low and then acts normal.
BRUCE HUNT
  • 3,754 POSTS
You say you replaced the fuel pump and the filter? The EGR valve should be behind the valve cover on the left. The PCV valve is located off of the valve cover. Test the PCV by pinching it closed with your fingers the hose coming off of it. There should be a clicking sound as it is pinched. If no sound check for leaks or replace it.
Suggested Repair
Check the EGR valve behind the valve cover on the left and the PCV valve off the valve cover. Pinch the PCV hose closed; it should click. If there is no click, check for leaks or replace the PCV valve.
Conversation Summary
A 1999 Honda Accord with 102,000 miles sometimes starts, then nearly dies right after the key is released: it cranks at a high idle, drops very low, then returns to normal. Plug wires and the fuel pump were already replaced. The expert recommends checking the EGR and PCV valves and testing the PCV by pinching its hose for a click, then checking for leaks or replacing it if there is no sound.
