2000 Honda Accord Hot Restart Stalls
ROSA
I have a weird problem. When starting the engine after driving it for an hour, the engine starts but then it stalls. For example, after work, I drive home. No problem starting the car at work. When I get home, I turn off the engine. After 20 - 30 minutes, I start the car again. This time, it seems like it's having a hard time to start. It sputters and sometimes it dies. When it dies, I try to start again and it starts. At this point, I can hear cranking sounds in the engine. I am able to drive fine, and no problem with stopping the car. It's just that I hear that weird sound.
I have no problem starting the car in the morning.
Again, this problem only occurs when I start the car 20 - 30 minutes after I've driven for a long time (an hour, 35 km).
I had my alternator and battery changed a year ago. The engine light is on.
Any ideas on what could be causing this?
Thanks!
Mar 7, 2006 at 8:55 AM
FISHERMAN
  • 937 POSTS
ok then you have to retrieve the codes stored on your computer, that way you will know what the problem is, when a sensor fails, the computer store the info.
Here is a guide to help you
find a place where they can scan your car computer, or if you want you can buy a cheap scanner visit amazon.
in some auto parts rent those scanners ask there.
May 18, 2017 at 4:31 AM
ROSA
Thanks for the reply.
I meant to say that the engine light is on before I actually start the car.
But when the car starts, the engine light is not on anymore.
Hope this is clear.
Sorry for the confusion and thanks again fisherman. :wink:
FISHERMAN
  • 937 POSTS
dont worry!
how abot the level of fluids?
Oil, Water, transmission, brakes..
when was the las time you do a tune-up to your motor?
the temperature neddle its about 3/8 from the bottom?
what kind of noise it came from the engine?
metal to metal... rubber... knocking?
how long has been doing that?
CADI1998JAZ
I have the exact same problem as ROSA.It's been suggested that the crankshaft sensor is the culprit.I had'nt got to a shop yet.Any other thoughts on this.
HMAC300
  • 48,601 POSTS
scan for codes auto parts does for free then check fuel pressure with a gauge auto parts rent it. you may need an adapter for that. see link.
May 18, 2017 at 4:32 AM
Suggested Repair
Scan the computer for stored trouble codes, then check fuel system pressure with a gauge. Also review fluid levels, recent tune-up history, operating temperature, and the type of engine noise. A crankshaft sensor was mentioned by another owner but was not confirmed.
Conversation Summary
A 2000 Honda Accord starts normally when cold, but after a long drive and a 20-30 minute wait it starts hard, sputters, and sometimes stalls before restarting. The owner also hears a cranking-type noise but can then drive normally. The check-engine light appearing before startup and going out afterward was clarified as normal. Experts advised retrieving stored codes and checking fuel pressure, while also asking about fluids, tune-up history, temperature, and noise. Another owner reported the same symptom and said a crankshaft sensor had been suggested.
