This issue is an intermittent one where after a cold start and after 2-3 follow-on starts at hot temperature. the engine will start but stall. I can start it again and rev the idle to keep it running but as soon as I put it in gear it shuts off. After repeating this a few times I can get it to run rough then it smooths out and runs fine until after another cold start. When I hook it up to diagnostics it indicates miss fire on all of the cylinder. I have replaced 3 of the 6 coil packs but I still get the same symptom. Like I indicated, it seems to happen after the engine is hot and after 2-3 stops and restarts. I have also replaced the Main Relay, but still occurs. Any ideas?
Apr 6, 2009 at 8:36 AM
