1999 Honda Accord Hard Start Stalls
I THINK YOU'RE RIGHT BECAUSE BASE ON MY OBSERVATION WHEN MY FUEL GETTING LOW 1/4 OF THE METER GAUGE, THIS PROBLEM MIGHT HAPPEN. IS IT STILL THE FUEL PRESSURE PROBLEM?
Got a same problem again bruce my car runs ok, ill bring my wife to her work then went to gas station to refuel after refueling my car runs smooth then engine stop again. now its hard to restart it again just like what i told before.
Got a same problem again bruce my car runs ok, ill bring my wife to her work then went to gas station to refuel after refueling my car runs smooth then engine stop while im driving. now its hard to restart it again just like what i told before. after 45 min ill try to restart my car now its working well again. he he Im going mad of it. if i have time i will go to garage then tell them to sort out the fuel pressure and change the fuel filter. is it right? thanks very much.
HAPPY NEW YEAR! BRUCE MY CAR CRANKS BUT WONT START NOW. WHEN ILL TRY TO START IT IN THE MORNING AFTER 1O SEC ENGINE STOP THEN GET ANOTHER TRY AFTER 30 MIN SAME THING HAPPENED. ILL BOOK MY SERVICED ON 22 OF JAN BUT MY CAR CAN'T WAIT FOR IT. PLEASE GIVE ME SOME IDEA TO START IT. THANKS A LOT.
yes lights works properly. where can i find the coil?
Suggested Repair
During a no-start, check fuel pressure and delivery, including the fuel pump, filter, and regulator. Also inspect a spark plug for fuel and confirm a strong blue spark. If there is no spark, suspect the ignition coil; if fuel and spark are present, consider the TDC/crankshaft sensor and verify that the check-engine light works.
Conversation Summary
The owner of a 1999 Honda Accord reported intermittent hard starting and stalling while driving, sometimes associated with low fuel and recurring after refueling. Expert Bruce Hunt recommended checking fuel pressure and related fuel-system components, then testing for fuel and spark during a no-start. He also suggested considering the ignition coil or TDC/crankshaft sensor if those checks pointed that way. No repair was confirmed.
