1997 Honda Accord Wont start
SAMMAR2
  • 1997 HONDA ACCORD
  • 4 CYL
  • FWD
  • 230,000 MILES
My car ran out of gas and I put more gas in it but it now it wont start. How can I get it to start?
Wednesday, January 13th, 2010 AT 2:42 PM
Do you hear the fuel pump come On when you turn key to run?
Fuel pump could be burned-up -check the fuel pressure if its within specs.
Tuesday, September 29th, 2020 AT 12:03 PM
SAMMAR2
Its sounds like its on the verge of catching when I try to start it and it sputters like its out of gas. I've tried turning the key without starting it several times before I try to start it but thats not working.
If you can hear the fuel pump-check the fuel pressure with gauge might not be producing the correct fuel pressure-could be very well be the fuel filter is clogged-up
SAMMAR2
Thanks I'll try that. Its past due for replacement anyway.
