1997 Honda Accord Car won't start
FREDDERF
  • 1997 HONDA ACCORD
  • 4 CYL
  • 216,255 MILES
My 97 honda accord won't start in cold mornings. The engine cranks and turns over and everything, it just won't catch on to actually run. The first time this happened, after trying for about one hour, it finally did. Last morning, it took about 4 hours. Tomorrow morning it probably won't at all. Please help!
Wednesday, November 26th, 2008 AT 1:29 PM
KHLOW2008
  • 41,814 POSTS
Hi fredderf,
There are some items that you need to do to verify which system is causing the fault.
1. Ignition, check for sparks at plug. Pull out a wire and attach a spark plug, ground it to engine and crank, checking for sparks while cranking. Spark should be bright blue and NOT orange.
2. Fuel. You need to check the fuel pressure at fuel rail.
3. Are the dash lights working while you are trying to start? Does the Check Engine Light goes off after 2 seconds of turning ignition switch to ON?
Tuesday, September 29th, 2020 AT 11:58 AM
FREDDERF
Thank you
