1997 Honda Accord car will not start
KAREN DELEON
  • 1997 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 137,000 MILES
My car will not start. The mechanic has changed the fuel pump and filter. Has new battery chected the alternater they said its good. I have a new distributor cap & rotor also we changed the coil pack had tune up and oil change? Please help
Friday, December 4th, 2009 AT 6:34 PM
KHLOW2008
  • 41,814 POSTS
Hi karen deleon,
Thank you for the donation.
What are the symptoms of the non starting?
Unable to crank?
Cranks but does not fire up?
Did you check what is missing?
Ignition sparks?
Fuel supply?
Did the Check Engine Lamp indicate while driving previously?
Was any repairs carried out prior to this happening?
Were the compression tested?
Did the engine overheat prior to this?
Here is a link that explains what to test for if you are not able to start the engine.
https://www.2carpros.com/how_to/index.htm
https://www.2carpros.com/kpages/first_things.htm
Go through the above links and let me know what you find.
Tuesday, September 29th, 2020 AT 11:59 AM
