1997 Honda Accord Front Vibration
Suggested Repair
Wash the tires and rims on both sides to remove snow, dirt, or gravel that can throw the wheels out of balance, then road-test. Motor mounts and tire rotation were already checked and found fine. Axles are less likely because the shake is intermittent and mainly under acceleration, not constant.
Conversation Summary
The owner of a 1997 Honda Accord reported severe front-end vibration, especially when accelerating, that eased when coasting. Tire balance, a CV boot replacement, motor-mount inspection, and tire rotation did not fix it. Driving in Colorado snow and gravel was noted. The expert said packed snow, dirt, or mud on the rims can temporarily unbalance the tires and recommended washing the tires and rims on both sides. Axles were considered less likely because they would usually cause a constant problem.
