Please respond back quickly..I need a car to go to class tonite..
:cry:
Wash the wheels and rims thoroughly inside and out to remove snow and dirt that can throw the wheels out of balance. If the shake and right pull continue, have tire condition, wheel balance, alignment, lug-nut tightness, and a sticking brake pad checked. These symptoms do not point to the timing belt.
A 2000 Honda Accord began shaking around 60 mph and pulling right the day after heavy snow in Minnesota. The owner asked whether alignment or an overdue timing belt was the cause. The expert advised against a shop visit first and recommended spraying the wheels and rims clean inside and out, noting that packed snow or dirt, a damaged tire cord, or a slightly sticking brake pad can cause similar symptoms. A later reply also suggested checking for loose lug nuts, imbalance, or misalignment if cleaning does not help.
