1998 Honda Accord Shakes Accelerating
STRETCHLIMO
When I get to about 45 mph and up my car starts to shake while I'm accelerating. If I let off the gas the car runs smooth. Is this a motor mount problem and if so, what type of costs can I expect to fix it?
Dec 16, 2006 at 1:16 AM
BRUCE HUNT
  • 3,754 POSTS
Visually look at the mounts. Does it continue to shake from 45 on up? Test the mounts by putting the vehicle in gear while holding the brake. Use first and reverse while watching the engine rotate or rise as the power is given to the engine. Someone watching the mounts should see excessive movement if the mounts are bad. There is a likelihood that the mounts could be bad there might be other things to look at as well. Wheel balance is another thing to look at.
Dec 16, 2006 at 3:55 PM
INTEGRAGUY29
  • 11 POSTS
Another good possibility is a failing CV axle joint, they tend to only exhibit vibration under load (accel/decel) while at speed.
this usually happens when the boot rips puking out all the grease. visually inspect the big rubber boots at the wheel ends of your axles for tears/leaking grease.
Dec 17, 2006 at 9:19 AM
STRETCHLIMO
Thanks, it was the mounts. All four are bad.
Dec 18, 2006 at 2:17 AM
Suggested Repair
Replace all four engine mounts, which the owner confirmed were bad. Before replacement, inspect the mounts for excessive movement under load and also check CV axle boots and wheel balance if vibration remains.
Conversation Summary
A 1998 Honda Accord shook from about 45 mph upward only while accelerating and ran smoothly when the throttle was released. An expert recommended visually inspecting the motor mounts, testing engine movement in gear with the brake applied, and considering wheel balance. Another reply suggested a failing CV axle joint and inspecting the axle boots for tears or lost grease. The owner later confirmed that all four motor mounts were bad.
