1995 Honda Accord
JORDAN69
  • 1995 HONDA ACCORD
Interior problem
1995 Honda Accord 4 cyl Two Wheel Drive Manual
I being having problems with the drivers window it would start going up but half way come off the track. I try to repaired but could not see nothing broken or loose. Can you help me. Thank You
Saturday, July 5th, 2008 AT 7:34 PM
KHLOW2008
  • 41,814 POSTS
Hi jordan69,
It is cable driven and running off track could mean the runchannels are dry and providing stiff resistance.
Lubricate the run channel with silicone or wax spray or replace the runchannel, use water to test first, spray some down the runchannels.
DO NOT use WD40 or equivalent, oil based lubricant would cause the rubber to become sticky.
Saturday, July 5th, 2008 AT 10:08 PM
