HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Accord
Drivetrain
Transfer Case
SPONSORED LINKS
1992 Honda Accord
CARLTON23
MEMBER
1992 HONDA ACCORD
Transmission problem
1992 Honda Accord 4 cyl Front Wheel Drive Automatic
while driving my car sometimes it will downshift from drive 4 to 2nd gear on its own and I was wondering if you knew what would cause it to do this.
Thursday, August 28th, 2008 AT 11:22 AM
KHLOW2008
MECHANIC
Hi carlton23,
Is the "S" light blinking?
I suspect either the Throttle Position Sensor or TCM is faulty.
SPONSORED LINKS
Friday, August 29th, 2008 AT 4:23 PM
CARLTON23
MEMBER
No but my drive 4 light remains on no matter what gear im in. Anymore suggestions
Saturday, August 30th, 2008 AT 6:37 AM
KHLOW2008
MECHANIC
Hi carlton23,
Only suggestion is to check the TCM wiring and you most probably need to reeplace the TCM.
Saturday, August 30th, 2008 AT 7:56 AM
Please
login
or
register
to post a reply.
Related Transfer Case Content
1992 Honda Accord
Engine Mechanical Problem 1992 Honda Accord 4 Cyl 2.2 Front Wheel Drive Manual In My 92 Honda Accord I Can Start My Car If I Move The...
Asked by
calvinasp
1992
HONDA ACCORD
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
1992 Honda Accord Idleing
Engine Mechanical Problem 1992 Honda Accord 4 Cyl Two Wheel Drive Manual When I Start My Car In The Morning I Know That It Should Have...
Asked by
jpbwana
1 ANSWER
1992
HONDA ACCORD
2006 Honda Accord Car Moves Without Being Given Gas
Transmission Problem 2006 Honda Accord 4 Cyl Two Wheel Drive Automatic 19k Miles Hi All, My Car Seems To Be Idleing To Fast Or...
Asked by
leorsiy
2006
HONDA ACCORD
1995 Honda Accord
1995 Honda Accord 4 Cyl Two Wheel Drive 135, 00 Miles My Accord Has Been Overheating It Starts Fine And Dosnt Overheat Until I Drive For...
Asked by
juice4200
1995
HONDA ACCORD
1986 Honda Accord Dogging Out?
1986 Honda Accord 4 Cyl Front Wheel Drive Manual Hi My Car Is Am 86' Lxi Accord And It Starts But As Soon I Give It Gas It Dogs Out...
Asked by
Rockstar5887
1986
HONDA ACCORD
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
Transmission Fluid and Filter Ford F-150
How to Replace Wheel Hub Assembly
Online car repair manuals
