1992 Honda Accord
CALVINASP
  • 1992 HONDA ACCORD
Engine Mechanical problem
1992 Honda Accord 4 cyl 2.2 Front Wheel Drive Manual
in my 92 honda accord I can start my car if I move the Distributor forward just passed where you bolt it to the engine and then when its started I move it back to where it should be and it runs find. But I have to do this everytime to start it. The timing is good and the Distributor is new
Monday, December 1st, 2008 AT 5:42 PM
MASTERTECHTIM
  • 4,750 POSTS
I just had a honda give me same kind of problem. It felt as if the timing was too far advanced and it would buck when trying to start, I found that the starter motor was bad causing not enough cranking power. It was a last ditch effort and it was the first time I had seen a starter act this way but thats what fixed it.
Monday, December 1st, 2008 AT 7:17 PM
CALVINASP
Ya the starter is new as well. I'm going to try and replace the computers under the carpet on the passengers side as well
Monday, December 1st, 2008 AT 9:18 PM
MASTERTECHTIM
  • 4,750 POSTS
Look real close at the connector at the computer because I have also seen them corrode fromwater intrusion and sometimes unplugging them and plugging them back in work temporarily
Tuesday, December 2nd, 2008 AT 6:59 AM
CALVINASP
I beginning to think its a fuel problem now or a sensor of some kind
Wednesday, December 3rd, 2008 AT 3:23 PM
