1992 Honda Accord Honda Accord 1992 won't start, only cranck
PANIKO
  • 1992 HONDA ACCORD
1992 Honda Accord 4 cyl Front Wheel Drive Manual
My honda accord 1992 only crancks but will not start. I have changed the distributor, the sparkplug wires, the timing belt is ok, the main relay clicks when I turn the switch, there is spark on the sparkplug wires the fuelpump is ok. When crancking it sometimes backfires in the carbureter. Can you help me with a solution? Or what else do I have to chek?
Saturday, September 13th, 2008 AT 10:52 PM
KHLOW2008
  • 41,814 POSTS
Hi paniko,
Carburetted model?
Thursday, September 18th, 2008 AT 9:09 AM
MSMEREDITH
  • 9 POSTS
I'm assuming it was running until you changed out the distributor and wires? I'd recheck the distributor placement of the timing--sounds like it could be off. Pull the rubber plug at on the top of the fly wheel, with your #1 piston on top dead center to see where your marks line up. Check your repair manual to see what your spark advance should be and adjust as necessary. Also, it's possible you have mixed up some plug wires if the distributor checks out.
Thursday, September 18th, 2008 AT 10:48 AM
