If you require further assistance, reply to this post and I will get back to you once notification is received.
SPONSORED LINKS
Monday, October 5th, 2009 AT 2:58 PM
GISLOC
MEMBER
I'm having the same problem with my 92 honda. Did every thing you did plus changed the main relay. Now my check engine light doesnt come on when you go to start the car like it suppose to. Was told it could possible be the ECU
Monday, October 5th, 2009 AT 4:44 PM
KHLOW2008
MECHANIC
Hi gisloc,
Recheck the PGM-FI main relay.
If you did any repairs at engine side, check the thermostat housing ground. If the ground connections is bad, it would not allow starting and the CEL would not show when ignition is turned ON.
Otherwise you need to test the indicator light circuit first. Check the ECM for contamination such as water entry etc.
Tuesday, October 6th, 2009 AT 8:22 AM
GISLOC
MEMBER
Havnt done any repairs recently. In the pass the car would start up and the die right away and then start right back up and stay on (every now and then). Now its been over a week and it wont start at all. Turns over has fuel, comp, and spark. Tried another main relay again still nothing.
Tuesday, October 6th, 2009 AT 3:23 PM
KHLOW2008
MECHANIC
Did you test if the injectors are firing?
Have you tried using starting fluids?
Is the sparks bright blue or dull orange?
