1992 Honda Accord
BIGGERTODD
  • 1992 HONDA ACCORD
Engine Mechanical problem
1992 Honda Accord 4 cyl Front Wheel Drive Automatic
92 honda with new distributor it is in time still wont start what do I do next help me
Monday, February 8th, 2010 AT 6:55 PM
ERNEST CLARK
  • 1,730 POSTS
Does the engine turn over but not start?
If so, check for spark at the plug. (With a spark plug checker)
If no spark, check the coil/coils. (You'll have to purchase a service manual that details the specs.)
If you do have spark, move to fuel pressure next. (Fuel pressure gauge)
If no fuel pressure, check pump. If you do have fuel pressure, check that the injectors are firing.
If you have good spark and fuel pressure (with injector firing), then check the crankshaft/camshaft sensors and the MAP/MAF sensors.
If everything checks out, then you have a bumb computer.
Monday, February 8th, 2010 AT 8:55 PM
