1992 Honda Accord No-Start
STEPOP1
This is a 1992 Accord with 132 CID 16 valve engine. It has about 70,000 miles.
Occassionaly when I drive the car and stop then get back in to start the car it will start for a split second and die. The all the turning over in the world will not start it. I shut it off and wait and after 5 minutes it will restart. It seems to me like something is shutting off the fuel or spark or both. Sometimes this is accompanied by a transmission problem too. This has an automatic with 4 drive speeds. When it is not starting the D4 indicator wil blink and after it DOES start the D4 gear will not have any power at all. In these cases I have to put it in a lower gear to drive the car. When I shut it off and start it again this problem often goes away.
Is there a sensor that can for any reason cut fuel and spark and could also effect the autio trans? If not a sensor, what?
May 27, 2007 at 8:29 PM
DESERTSHADOW
  • 5 POSTS
The main relay's are famous for being intermittent, ESPECIALLY in high-heat! Your symptoms are classic. There is a great myspace where a guy has pix for step-by-step replacement of Main Relay, located beneath dash above steering column/gas pedal.
Good Luck
Sep 30, 2020 at 3:15 AM
BRUCE HUNT
  • 3,754 POSTS
Pull out the EFI relay and the location given by desertshadow is right. Look at the connections and resolder or replace the unit.
Suggested Repair
Inspect the main EFI relay under the dash above the steering column and gas pedal. Check the connections, then resolder them or replace the relay, which commonly fails intermittently when hot.
Conversation Summary
A 1992 Honda Accord with about 70,000 miles sometimes starts briefly after a stop, then dies and will not restart until it sits for about five minutes. The D4 indicator may blink and D4 may have no power until the car is restarted. Replies identify the main EFI relay as a classic heat-related intermittent failure and recommend checking its connections and resoldering or replacing the unit.
