Service engine stays on, disconnecting the battery does not work, engine now is hard to start, smells like the engine is flooded, at times, or appears to not be getting enought gas, if one pumps the gas pedal, one can get it started, shut it off, try to restart same thing. I think it is a bad sensor perhaps but I don't know which one, I also need know what wire colors are that go to the coolant temp sender, orig connector plastic around it is broken. got brittle from age. also does this car have a obc, my haynes manual makes no mention of one. Thanks
Jul 29, 2006 at 1:59 AM
