Have attempted to pass the local emmissions test and each time have failed. I continue to recieve a high CO and HO?. I have had the Catalytic converter replaced, replaced the Rotor and Plug's, and ran a injector cleaner through the fuel system as well as ran the tank near emty with the fuel additive. The check engine light is on but as near as i can tell the blinking LED under the drivers seat is illuminating 6 times indicating a coolant tempature sensor.
The car does have a good Idle, however, it does at time seem to miss occasionally and I need to set the idle to 700 as it was high when I had it in the test center last.
Can you advise me please as to what other direction to take.
Thanks
Ken
Thanks
Ken
Jan 26, 2009 at 9:39 AM
