Electrical problem
1988 Honda Accord 4 cyl Wheel Drive Type unknown Automatic 170000 miles
firstly i want to say thanks for this service you guys are offering. i really is great to car repair laymen like myself.
i have a 1988 accord lxi that was running fine 4 years ago. it had to sit due to title problems and during that time, part of the car was flooded. the engine was not covered in water, but probably a good bit of the underside. on to today.......everthing is all dried up now and i have replaced the battery, spark plugs/wires, distributor cap, rotor button, fuel filter, fuel pump and ignition fuses (40A) and the car will turn over but not start. i tested the ignition coil per haynes manual, and one of the resistence checks failed (the manual says if any tests fail, replace it but i havent done so yet). i am not getting any spark from the plugs (screwdriver to plug test) but i am getting a spark from the ignition coil ((screwdriver to high tension terminal test). every now and then after i have attempted to start the vehicle, one of the cooling fans comes on with the key off! and my rear lights stay on when the battery is connected, thus i have to disconnect it when i stop working on it. my main concern is the fact that it wont start and i mentioned the other issues in the event that they have something to do with that. i hope you guys can help me. i am truly stuck at this point. thanks in advance for your help.
Feb 13, 2008 at 2:37 PM
