blower motor not working?
185,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JIMMYDEAN817
The heater blower motor in my SUV is not working.
Nov 13, 2016 at 7:13 PM
HMAC300
  • 48,601 POSTS
check items in picture then if still not working see if blower is getting power or not. it may be control head which will need a mechanic to scan for codes.
Jul 6, 2020 at 12:42 PM
BROSVGS
  • 7 POSTS
hello here I am again am trying to replace heater blower motor on 00 Durango but it seems that is going to be a lot of work. My question is do I have to remove the hall dash to remove the motor Thanks in advance any help well be appreciated.
Aug 6, 2020 at 3:52 AM (Merged)
MLDANIELS2000
  • 227 POSTS
This one will unfortunately going to require you to pull the dash to remove the hvac unit for blower motor replacement.
BROSVGS
  • 7 POSTS
thank you very much for your help.
MLDANIELS2000
  • 227 POSTS
Did you check the blower resistor?
APHARARI73
I want to now whats happening with my ventilation unit on the my Durango 2000, some times it start, and some times it doesnt, some times it takes like 20 mins to start, I dont know if its the blower, the blower resistor, or what, the compresor its working, but ther is no air coming out. Some times it takes 3 days to start, I just leavit on. How can I fix this. I cant find the blower resistor, someone told me that it was under the glove comp. but it isnt.
CARADIODOC
  • 34,407 POSTS
Worn brushes in the blower motor. Very common on high mileage vehicles. The fan would still work on the highest speed if the resistor block was burned out.
caradiodoc
JAVC2000
The electric blower does not stop, pull the relay and stops...if its a switch, where is it located? Can I still drive the car?
  • 75,988 POSTS
Try swapping the relay with a like one and see if it continues to come on-
JAVC2000
I take it back, I think i just pulled the fuse under the hood, where would the relay be at, please
2CP-ARCHIVES
  • 4,540 POSTS
what will make no heat come out of vents from heater coil heater coil is good thomasat is good blower motor is new but no heat will come out
low coolant, clogged radiator, clogged heater core or blown head gasket from overheating
