03 Durango blower speed selector
2003 DODGE DURANGO
BMHEWITT
03 Duranago 55,000 miles 4.7L--- Question #1 The blower speed selector for the heater and AC has 4 speeds. My problem is that on speed 1 and 4 the air completely stops blowing and on speed 2 and 3 the air blows out normally. Why is this happening? Question #2 The second row air vents do not blow out any air (hot or cold, front control or rear control) and the third row air vents blow air just fine. Why is this happening? Thanks
Jul 8, 2007 at 3:38 AM
FRANKIEFUEGO
  • 18 POSTS
Mine is doing the same thing, just in different blower positions. Same thing with the back blower. Let me know if you find out what the problem is.
Oct 1, 2007 at 12:27 PM
CHUCKIE3225
[quote:5bd7630be7="bmhewitt"]03 Duranago 55,000 miles 4.7L--- Question #1 The blower speed selector for the heater and AC has 4 speeds. My problem is that on speed 1 and 4 the air completely stops blowing and on speed 2 and 3 the air blows out normally. Why is this happening? Question #2 The second row air vents do not blow out any air (hot or cold, front control or rear control) and the third row air vents blow air just fine. Why is this happening? Thanks[/quote:5bd7630be7] The problem your having with your blower motor is the resistor. on the passenger side underneath the dash you should see the blower housing and an green and black wires. then a conector that turns in to a 5 wire pig tail.there 2 8mm screws that hold the resistor in place . that will fix that problem with the rear air i would have to look at but i will take an educated guess and say that the blend air doors inside of the hvac housing are broke...this isn't good it's going to be kinda pricing to fix due in part that the whole dash board has to be pulled out to get the hvac house out to fix it if thats even the case it might not be though.
Nov 9, 2007 at 12:03 PM
