blower motor
2003 DODGE DURANGO
110,000 MILES • 1.7L • V8 • 4WD • AUTOMATIC
SMTY111
the car started blowing the resister out so after replacing one per month (about three total) I put on a new blower . one month later it blew another resistor . I do not know what else to replace .
Jul 27, 2016 at 2:34 PM
WRENCHTECH
  • 20,761 POSTS
The blower motor is the only load on the resister. Make sure none of the connectors have overheated and caused discoloration in the plastic or the terminal. That will cause high resistance. Other than that. it has to be the quality of the parts, either one of them.
Make sure these resisters are actually burnt out and it is not just the connector.
Jul 27, 2016 at 2:57 PM
SMTY111
It is always the same discolor on one of the connectors on the resistor. Any ideas on what brand or part numbers on blower motors and resistors that would be the better quality part to buy ?
Jul 28, 2016 at 3:10 AM
WRENCHTECH
  • 20,761 POSTS
Everything will be Chinese made except factory Mopar parts.
You need to replace any burnt connectors.
Jul 28, 2016 at 4:17 AM
