Heat goes cold for about thirty seconds
ADAM PIETRASKIEWICZ
  • 2004 CHEVROLET IMPALA
  • 3.4L
  • 6 CYL
  • 220,000 MILES
My niece noticed her heat all the sudden getting cold while she was driving. I checked her antifreeze when engine was cool. Looks like it definitely needs to be flushed. As the car came to normal temperature once the heat started to blow cold, I held down gas a little and noticed the temperature gauge drop a tiny bit and raise back up within about thirty seconds and it started to blow hot again. The other thing I noticed is after the car was running for about thirty minutes, neither cooling fans came on and she has not had any problems overheating. I am baffled.
Saturday, April 1st, 2017 AT 4:38 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,323 POSTS
It sound like the coolant level is low or the heater core is plugged here is a guide to ehlp you get the problem fixed.
https://www.2carpros.com/articles/car-heater-not-working
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Tuesday, April 4th, 2017 AT 2:25 PM
