2010 Dodge Avenger Headlights Out
135,000 MILES • 4.0L • 4 CYL • 2WD • AUTOMATIC
CDERVIN13
Passenger side headlights both high and low beam lights not working. I have changed the bulbs, and even changed the TPIM with no luck. The blinker and running light work on that side. The driver's side lights work great as do all other lights.
Sep 24, 2021 at 3:05 PM
  • 110,251 POSTS
The idea that neither high nor low work, have you confirmed the light has a good ground? Also, have you inspected the connector to make sure nothing is bent, damaged, or corroded?
If you look below, I attached the wiring schematic for the headlamps. I highlighted the high and low beams for the right side. First, make sure there is continuity to ground via the black wire. The ground location is at the right strut tower.
If the ground is good, then disconnect the connector and check the white wire with a tan tracer for power with the low beam turned on. Do the same with the white wire with a light blue tracer for the high beam.
If we have power and ground, the bulb should work. One or the other is the issue.
Let me know what you find.
See pics below. Note: The schematic was one page long. However, I had to cut it in half to make it readable for you. I did overlap the pics so you can follow from one to the next.
Sep 25, 2021 at 12:53 PM
Suggested Repair
Check continuity to ground on the black wire at the right strut tower and inspect the headlamp connector for bent, damaged, or corroded terminals. With the connector disconnected, test the white/tan wire for low-beam power and the white/light blue wire for high-beam power. If power and ground are both present, the bulb should work; otherwise repair the missing power or ground.
Conversation Summary
The owner of a 2010 Dodge Avenger reports that both the high and low beams on the passenger side do not work after replacing the bulbs and the TPIM. The turn signal and running light on that side work, and the driver-side lights are fine. The expert recommends confirming the black-wire ground at the right strut tower, inspecting the connector, and checking power on the white/tan low-beam wire and white/light blue high-beam wire.
