2000 Dodge Avenger Shuts Off While Driving
THEBIGT
after driving my 2000 dodge avenger awhile it shuts off and wont start.But after sitting for a half hour or so it will start and i could drive it for a couple of miles. And it will shut off again. so what could be wrong. I was told the fuel pump but i think its something elseAnd the milage is 125000
May 26, 2007 at 6:06 PM
E40WATER12
  • 522 POSTS
Has youre car fuel fitler been changed?. Also are u getting check engine light on?. I am thinking you may want to get youre fuel pump pressure tested, Also you could have a problem with youre crank sensor.
May 27, 2007 at 1:10 PM
JULIOGLZF
Same trouble without found solution, I spend much money try to repair ir without success.
Please some one help us,we are any Avenger´s Owners with this trouble
Aug 10, 2007 at 3:17 PM
Suggested Repair
Check whether the fuel filter has been replaced and whether a check engine light is present. Have fuel pump pressure tested, and also inspect the crankshaft position sensor.
Conversation Summary
A 2000 Dodge Avenger with 125,000 miles shuts off after being driven, will not restart until it sits about half an hour, then stalls again after a few miles. The owner was told it might be the fuel pump but suspects another cause. The expert suggested checking the fuel filter and check engine light, testing fuel pump pressure, and considering a crankshaft sensor problem. Another owner reported the same unresolved issue.
