Has spark, no power to fuel pump or injectors
93 CIVIC DX
  • 22 POSTS
No. Pin #7 at main relay does not have any voltage.
If I jumper wire #5 to #7 I can give #7 power that way. Otherwise #7 has 0 voltage.
Friday, August 17th, 2018 AT 11:10 AM
93 CIVIC DX
  • 22 POSTS
I am going to do some more continuity checks between sensors and ECU pins. Also check ECU ground pins for continuity to ground. Maybe tomorrow if it does not pour rain. Going to babysit my grandson now.
Thanks for your help!
Friday, August 17th, 2018 AT 11:35 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
#7 goes straight to the fuse panel so I would say that is the issue. Check the wiring diagrams to confirm #7 on the PGMFI
Saturday, August 18th, 2018 AT 1:00 PM
93 CIVIC DX
  • 22 POSTS
Okay. I will do a continuity check. Do you know which fuse #7 connects to?
Saturday, August 18th, 2018 AT 2:09 PM
93 CIVIC DX
  • 22 POSTS
Actually, I think #7 connects directly to the fuel pump harness. I did a continuity check from the main relay harness pin #7 to the fuel pump harness and there was continuity there. (No breaks in the wire.)
Saturday, August 18th, 2018 AT 2:11 PM
