The chevy cavalier 2001 with twin cam DOHC engine had water pump severe leak. i put in new water pump. i marked the cam shaft sprocket and chain and crank shaft with paint marker to placement. i put back the old chain tensioner. put it all back. I used a ratchet - socket on the crank shaft to rotate it. now i tried start the car and wont start seems turn over slow too. Could i have damaged the valves by using ratchet on the crank shaft ? What do i do now ? take the timing chain cover off now and try new chain and parts ?
need help here.
Anthony
need help here.
Anthony
Nov 1, 2026 at 2:48 PM
