2001 Chevrolet Cavalier Won't Start
GEDAR
My Cavalier made the sound a car makes if you try to start it after its already been started but it wasn't started when it made that sound this time. Then next time I tried to start it, there was no sound at all. My lights, radio, fan all work fine so I do not think it is the battery. I am obviously not a car guy but I was wondering if anybody had any ideas as to what this could be so that I might have an idea of the cost to fix it. Sory if I made this sound too confusing, remeber, I am not a car guy.
Oct 23, 2006 at 6:26 AM
JDL
  • 16,098 POSTS
Sorry for the late reply.
If it makes that terrible grating noise, I have to check the starter and the flywheel. If the starter won't crank, I'd have to check voltage and ground circuit for the starter. Any testing at the starter make sure tranny is in park or neutral and the parking brake is set.
I realize this an old post, you probably no longer own this vehicle. In the future hope you don't have any vehicle issues. If you do, keep the site in mind. They are always trying to improve the site, more moderators and it's free.
Have a good day.
Mar 22, 2015 at 5:20 AM
Suggested Repair
If the starter made a grating noise, inspect the starter and flywheel. If it will not crank at all, check the starter voltage and ground circuits. Keep the transmission in park or neutral and set the parking brake during testing.
Conversation Summary
The owner of a 2001 Chevrolet Cavalier said it made a grating sound like an already-running engine being cranked, then later made no sound when starting was attempted. Lights, radio, and fan still worked, so the battery was not suspected. The expert advised checking the starter and flywheel for the grating noise, and checking the starter voltage and ground circuits if it will not crank, with the transmission in park or neutral and the parking brake set.
