02 Cavalier sometimes will not start but pump is on
FHARRIS
  • 2002 CHEVROLET CAVALIER
My car will run perfectly fine but sometimes will not start. I have replaced the fuel filter, and I can hear the fuel pump starting up, but the car will not turn over. It cranks but wont start. Then, twice, I had my car towed to the dealer and it started up when the mechanic got in. It has had hard starts where it takes a bit of cranking to actually start it but twice now, it would not start at all until I had it towed. This has happened only since I replaced the fuel filter (not starting), but the hard starts have been happening for a while now. Has anyone had this problem before? I don't want to replace the fuel pump if it is something else.
Wednesday, August 1st, 2007 AT 10:37 AM
JCRESWELL
The same thing is happening to my car now. I was having problems with it starting. It would work occasionally and at times it wouldn't. I took it to a mechanic and was told after a diagnositcs test that it was the fuel pump, yet I can hear the fuel pump turning on when I turn the ignition. I have replaced the fuel filter and I am still having problems. The mechanic quoted me a steep price of 850 dollars to fix it. I am concerned that I am being ripped off considering the pump only cost approx. 240 dollars. I wanted to get a little more insight before I buy a fuel pump and that not be the problem. If anyone has any comments please let me know.
Friday, August 3rd, 2007 AT 6:01 PM
If the pressure is not in specs it will prevent it from starting. Recommend a fuel pressure check if that's okay-have the crankshaft position sensor check for a start.
Saturday, August 4th, 2007 AT 6:46 AM
FHARRIS
Is there any possibility that it is the fuel relay?
Tuesday, August 7th, 2007 AT 8:01 AM
DROVECRAZY
I am haveing sort of same prob it turns over but will not catch every now and then it is fine but for most part it is not, I have replaced coil, plugs, wires, fuel filter, and checked fuel pressure it is all fine, I am running out of things to check
Monday, February 11th, 2008 AT 7:30 PM
