2000 Cavalier won't start after running out of gas
MUCKRAIDER
  • 2000 CHEVROLET CAVALIER
My daughter ran the car out of gas. Now it will occasionally start but dies right away. I have replaced the plugs and insured that they spark, and I have replaced the fuel filter. The fuel pump noise is the same as before it was run out of gas. I can't fine the test port to check the fuel pressure, at least there isn't one on the rail. I also checked all the fuses going to the pcm and they are okay. Is there anything I'm missing before I go to the expense of replacing the fuel pump?
Sunday, May 6th, 2007 AT 6:35 PM
WESMAN2440
  • 23 POSTS
Try taking the air intake hose off and spray some starter spray in the injector
do this before you do anything else :)
Sunday, May 20th, 2007 AT 12:04 PM
XTAKN4LIFEX
My 2001 cavalier did the same thing. Its your fuel pump.
Monday, June 11th, 2007 AT 9:34 PM
E40WATER12
  • 522 POSTS
I would look into getting youre fuel pump tested for pressure.
Wednesday, June 13th, 2007 AT 4:22 AM
