2000 Chevy Cavalier no start
156,000 MILES • 4 CYL • FWD • AUTOMATIC
MONY_10
Car has dohc 2.4l engine. car was running and just died. I can hear fuel pump prime, but does not seem to fire. I changed module coil assembly with known good one with no luck. Any help appreciated.
Oct 27, 2010 at 11:10 AM
SATURNTECH9
  • 30,868 POSTS
So you don't have any spark?
Oct 27, 2010 at 1:15 PM
MONY_10
no spark, any ideas?
Oct 27, 2010 at 2:26 PM
SATURNTECH9
  • 30,868 POSTS
So did you swap out the coil's and the module?Can you rent a scan tool and see what code's you have?I suspect you could have a bad crank shaft position sensor.
Oct 27, 2010 at 4:58 PM
MONY_10
yes, I've also checked the crank sensor and it has .734 ohms of resistance.
Oct 28, 2010 at 12:27 AM
SATURNTECH9
  • 30,868 POSTS
So when you swapped the module coil assembly with a known good one was that the coil and ignition module?You need to rent a scan tool and see if you have any code's that would be a good starting point.
Oct 28, 2010 at 3:34 AM
