1994 GMC Yukon Jumping Speedometer
PULSTI
  • 28 POSTS
my spedometer jumps out of control in my 94 GMC Yukon. Where is a good place to start looking for the problem and the cause? Thank You
Feb 21, 2007 at 6:19 AM
CHEVY22
  • 1,375 POSTS
there is alot of diagnostic time involved , you would have to have a scanner to check the input speed signal from the transmission vss vehicle speed sensor is there and ok then move up to the clutser
Feb 22, 2007 at 5:19 AM
Suggested Repair
Use a scanner to confirm the transmission vehicle speed sensor (VSS) input speed signal is present and good, then inspect the instrument cluster if the signal checks out.
Conversation Summary
The owner of a 1994 GMC Yukon reports the speedometer jumps out of control and asks where to start. The expert says diagnosis takes time and recommends scanning the transmission VSS speed signal first, then checking the instrument cluster if that signal is OK.
