2004 GMC Yukon Speedometer Sticks High
HEXAFAMILY
2004 GMC Yukon XL, 60,000 miles, 5.3 V8, auto, 4X4. Speedometer on occasion while driving on the highway, begins to climb until it reads past 120 mph, and sticks. After some small slow trips it works its way down and begins to work correctly. When malfunctions occur, it is during highway travel.
Oct 30, 2007 at 5:46 AM
  • 75,988 POSTS
Have your vehicle speed sensors check might be 2 of them one at the transmission and the other at speedo head.
Nov 1, 2007 at 11:27 AM
HEXAFAMILY
Found GM has a recall on gauge clusters for GM trucks from 2002 through 2005? for bouncing and malfunctioning. Had cluster replaced free of charge.
Dec 4, 2007 at 2:31 AM
Suggested Repair
Have the instrument cluster checked under the GM gauge-cluster recall for 2002-2005 trucks. Cluster replacement resolved the speedometer climbing past 120 mph and sticking. If the problem returns, also inspect the vehicle speed sensors at the transmission and speedometer head.
Conversation Summary
A 2004 GMC Yukon XL speedometer occasionally climbed past 120 mph and stuck during highway driving, then slowly returned to normal after short trips. An expert suggested checking the vehicle speed sensors at the transmission and speedometer head. The owner found a GM recall covering bouncing or malfunctioning gauge clusters on 2002-2005 trucks and had the cluster replaced at no charge.
