2003 GMC Yukon Stalls on Acceleration
Might want to have this items check: Throttle actuator control module,Vehicle speed sensor,Manifold absolute pressure sensor/ Intake Air temperature sensor
Suggested Repair
Have the throttle actuator control system inspected. In this case the throttle was not allowing proper airflow when the accelerator was pressed, which caused the engine to stall; the dealer repaired it and the truck ran normally afterward. Related checks can include the vehicle speed sensor and the MAP/IAT sensors if the problem returns.
Conversation Summary
A 2003 GMC Yukon with about 83,000 miles cranked slowly, then stalled or would not accelerate after a weak battery was replaced, sometimes showing a slow engine speed message. An expert suggested checking the throttle actuator control module, vehicle speed sensor, and MAP/IAT sensors. The dealer found the throttle was not letting air through when the gas pedal was pressed, repaired it, and the truck ran well again.
