1994 GMC Yukon Ball Joints
PULSTI
  • 28 POSTS
I was told that to change my ball joints on a 94 Yukon I needed a compressor or something to pop the balls into the socket, I was also told that I dont, but I would need to saw or drill out the old ones to replace them with new ones. Is this a job that I can do without any special tools and/or equipment? I really need them replaced but cannot afford the hundreds of dollars that the shops are asking for!!
Please give me some suggestion, thank you.
Jun 4, 2006 at 7:19 AM
BURRBRIAN
  • 158 POSTS
Allthough I don't take them for gospel, Autozone's site gives you step-by-step on removal and they have a loan-a-tool program for specialty tools if any are needed. If the ball joints are factory with rivets then, yes you have to drill them out to remove them, but the new ones should go back in with nut and bolt. Hope this gives you enough to get you going. Good luck :D
Jun 4, 2006 at 7:46 AM
Suggested Repair
If the factory ball joints are riveted, drill out the rivets to remove them. Replacement joints install with nuts and bolts. Follow Autozone removal steps and use its loan-a-tool program if specialty tools are needed.
Conversation Summary
The owner of a 1994 GMC Yukon asked whether ball joints can be replaced without special tools after receiving conflicting advice about using a compressor or drilling out the old joints. The expert said factory riveted joints must be drilled out, replacements bolt in, and Autozone offers instructions and tool loans.
