1992 GMC Yukon Temp Gauge Dead
KGR624
1992 yukon 2 door 103,000 350 5.7 liter. I can not get a temperature reading on my gauge. I have replaced the temperature unit on the block but still no reading. I checked wire and it is good untill it get to fire wall. Anythingelse I can check before taking the dash apart to find out gauge is bad?
Nov 6, 2007 at 7:38 AM
MERLIN2021
  • 17,250 POSTS
Coolant temp gauge measures current resistance from the temp sending
unit,mounted in the cylinder head. The sender has a resistance of 53.4 ohms at
257 degrees, and 1200 ohms at 104 degrees. As the tem increases the current to
the gauge increases due to less resistance, causing the gauge to move to hot.
Try testing the guage by applying volts to the hot wire..gauge should go
towards hot! If not, the gauge is NG or the wire!
Nov 6, 2007 at 7:52 AM
Suggested Repair
Test the coolant temperature gauge by applying voltage to the hot wire at the gauge. If the needle does not move toward hot, the gauge is bad or the wiring is open. The sender should read about 1200 ohms at 104 degrees and 53.4 ohms at 257 degrees.
Conversation Summary
A 1992 GMC Yukon with a 5.7L engine shows no temperature gauge reading after the block temperature sender was replaced. The owner confirmed the wire is good up to the firewall and asked what to check before removing the dash. The expert explained that the gauge responds to sender resistance and recommended applying voltage to the hot wire; if the gauge does not move toward hot, the gauge or the wire is faulty.
