2005 GMC Yukon Dual Exhaust Sound
DSPASCHA
I want to put dual exahust on my 2005 Yukon Denali, but I can only do so by removing my spare tire. The guy at the exhaust shop told me it is possible to get the same sound just by replacing the stock muffler with a louder model. Is this possible?
Jul 30, 2006 at 5:08 AM
DEMEARSJR
  • 110 POSTS
What brands did you look at.
If the "guy" works at an exhaust shop he should be able to build you a custom exhaust.
Jul 30, 2006 at 4:24 PM
DSPASCHA
The brand would be flowmaster either 3 chamber or 2 chamber. He said he could not safely build a custom system it was entirely too tight. And I would agree with this also after looking at it on the lift
Jul 31, 2006 at 2:07 AM
DEMEARSJR
  • 110 POSTS
Sound and performance are 2 different things.
Some mufflers do have better sound and some do help your perfomance, but if your looking for an exhaust system try godfathercustoms.com
Jul 31, 2006 at 6:01 AM
VEGASMSTRJ
  • 50 POSTS
if he changes out your mufflers it will be quite a bit louder but for real performance u should get a hi-per exhaust.
Sep 28, 2006 at 9:50 AM
Suggested Repair
If the goal is sound only, replace the stock muffler with a louder aftermarket unit such as a Flowmaster. For real performance, use a high-performance exhaust. A custom dual system may not fit safely because of tight clearance around the spare tire.
Conversation Summary
The owner of a 2005 GMC Yukon Denali wants dual exhaust but would have to remove the spare tire. The exhaust shop said a louder muffler could produce similar sound and that a custom system would be too tight to build safely. Experts said sound and performance are different, a muffler change can make the vehicle louder, and a high-performance exhaust is needed for real performance gains.
