Engine wont crank
BBEARD84
  • 2003 GMC YUKON
Engine Mechanical problem
2003 GMC Yukon V8 Four Wheel Drive Automatic
car fully powers up electronically, engine does not crank up at all
Monday, May 1st, 2017 AT 10:13 PM (Merged)
Are we talking about its cranking over and refuses to start or won't crank at all/nada
Cranking and no start do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
No crank/nada:
Could be the battery/connection, alternator, starter, starter relay, park and neutral position switch and ignition switch
