1995 GMC Yukon starter problem
144,439 MILES • V8 • 4WD • AUTOMATIC
FRANK BAUERSCHMIDT
I have 1995 GMC Yukon that startered when I bought it, then it wouldn't start once I got it home. I saw that the braided ground wire broke from the frame. I hooked that back up & disconnected the neg. battery terminal & reconnected it & it started. I shut it off & I can't get it to start again. What can it be ?
Dec 12, 2009 at 9:41 AM
  • 75,988 POSTS
Does it start for a few secs and dies out or just won't start at all
Dec 12, 2009 at 9:46 AM
FRANK BAUERSCHMIDT
It started and ran fine, then when I shut it off it wouldn't start (turn over) not even a click from the starter.
Dec 13, 2009 at 12:53 AM
  • 75,988 POSTS
Double check the battery and connections if okay-check and test the following: Starter, starter relay, park/neutral switch and ignition switch.
Dec 13, 2009 at 2:31 AM
