secondary air injection
LMM66
i have a 2000 gmc sonoma 4x4 4.3 v6. the check engine light came on. i read the codes saying - secondary air injection malf and cyl #2 misfire detected. i replaced the plugs and wires, and the light went away for about 500 mi and then came back with the same problem. what is secondary air? are these 2 problems related? the truck is getting very poor gas mileage.
Aug 16, 2007 at 7:55 PM
  • 75,988 POSTS
[quote:3c1bed742c="lmm66"]i have a 2000 gmc sonoma 4x4 4.3 v6. the check engine light came on. i read the codes saying - secondary air injection malf and cyl #2 misfire detected. i replaced the plugs and wires, and the light went away for about 500 mi and then came back with the same problem. what is secondary air? are these 2 problems related? the truck is getting very poor gas mileage.[/quote:3c1bed742c]
P0410 secondary air injection malf
what is secondary air- it is from the air pump to help oxidizes the exhaust gases so that the catalytic converter operates efficiently.
P0302 No.2 misfire could come from a weak coil/lean mixture/dirty injectors/vacuum leaks/burn exhaust valve/bad gas/low fuel pressure/Open EGR
Aug 16, 2007 at 9:15 PM
