1992 GMC Sonoma Rough Idle
SLIMTHUGG
i have a 1992 gmc sonoma with aobut 153000 miles and its a 4.3 liter and my idleings a little rough i replace the map sensor, ignition module, spark plugs, spark plug wires, distributor cap and rotor, and the o2 sensor and i still cant figure out what the problem is I also checked for any vaccum leaks but that isnt it either. I was just wondering if you could give me a couple ideas what it could be? :)
Mar 23, 2007 at 5:35 PM
SERVICE WRITER
  • 9,123 POSTS
Sometimes carbon build up can be a problem as it collects on intake valves, iac motors and throttle plates. Worth cleaning them regardless if it solves it.
Mar 24, 2007 at 12:23 AM
TRUEFIRE04
  • 35 POSTS
yeah use this stuff caled Seafoam / Motor Treatment, run it threw your brake booster vacum line....you will see alote of smoke thats ok...its the injectors being cleaned, also put have of the bottle in your gas tank. when putting it in your brake booster line, just poor slowly the line will suck it out, make sure you do it slow though....so it get all clened, and your idel will , should drop back to normel....mine did
https://images.2carpros.com/forum/automotive_pictures/71740_sea_foam_1.jpg
May 1, 2007 at 12:36 AM
SERVICE WRITER
  • 9,123 POSTS
I'll second that on the seafoam, but disagree on what you're cleaning. By putting into the vacuum line (as you should), your bypassing the injectors and putting it directly into the intake, cleaning some of the intake but more importantly the intake valves.
May 1, 2007 at 8:42 AM
TRUEFIRE04
  • 35 POSTS
well you also have to put half a bottel in the tank, or get 2 bottels and 1 in the vacumline and 1 in the gas tank.....i did both...and the truck rund great
May 2, 2007 at 6:25 AM
SERVICE WRITER
  • 9,123 POSTS
I was always afraid of putting it in the tank. Some of the fuel pump manufacturers said that it could damage the pumps, so I just stayed away from it. Might be their way of explaining away a warranty? I see on the can about adding it to the tank and the it's a fuel stabilizer too. Didn't know that!
I get a little leary stepping on what may be thin ice, but I heard enough other folks adding it like that and it seems like there haven't been problems.
I friend had added acetone to his tank, and had great performance results, within a year he had to replace the pump...coincidence maybe?
May 2, 2007 at 8:34 AM
TRUEFIRE04
  • 35 POSTS
most fuel treatments tell you on the bottel to add to tank....i wouldn't add acetone to a fuel tank at all, think of it this way, git you some fingernail polish remover stick some ruber house in it and leave it for a few days....what happens? it turns to mush...think about wout fuel lines...the rubber parts, think of your seals....wow.
May 3, 2007 at 4:49 AM
Suggested Repair
Clean carbon buildup from the intake valves, IAC motor, and throttle plate. Seafoam drawn slowly through the brake booster vacuum line can clean the intake and valves; adding it to the fuel tank is optional, though some fuel-pump makers caution against it.
Conversation Summary
A 1992 GMC Sonoma 4.3L with about 153,000 miles has a slightly rough idle after the MAP sensor, ignition module, plugs, wires, distributor cap and rotor, and oxygen sensor were replaced and vacuum leaks were ruled out. The expert suggested carbon buildup on the intake valves, IAC, and throttle plate. A user recommended Seafoam through the brake booster vacuum line and in the tank. The expert agreed with the vacuum-line method for cleaning intake valves but was cautious about adding it to the tank because of possible fuel-pump concerns.
