1996 GMC Sonoma A/C Mode Won't Switch
CDAWG
1996 GMA Sonoma: For the past few months, my air conditioner will not switch from the defroster (blowing out of the dash) and the floor vents to the vents that face the driver and passenger. I have no problem with the speed of the fan or turning it off and on. Does anyone know what would cause this? Is something sticking? Thank you for your prompt response as it is getting a little warm to run without the A/C. Thank you for your prompt response!
Apr 13, 2006 at 5:23 AM
LOSONE
  • 1,616 POSTS
Find the black vacuum ball in the engine compartment. It has a plastic hose from the intake and quite often the hose will burn or come apart. I am sure it will fix the problem. i have fixed a ton of them. Good Luck
Apr 13, 2006 at 11:15 AM
Suggested Repair
Inspect the black vacuum ball in the engine compartment and the plastic hose running from the intake. Replace or reconnect the hose if it is burned, cracked, or separated, which commonly restores vent mode switching.
Conversation Summary
The owner of a 1996 GMC Sonoma says the climate system will not switch from the defroster and floor vents to the dash vents, while fan speed and on/off still work. An expert recommends checking the black vacuum ball in the engine compartment and its plastic hose from the intake, which often burns or comes apart and causes this problem.
