Truck will not start, replaced crank sensor 3 days ago, fixed problem, but will not start today.
Monday, May 25th, 2009 AT 5:11 AM
MECHANIC
Check if you're getting spark if not recheck the CPS
No spark
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
