A few days ago I went to start my pickup but all it did was crank. I puled a plug to check for spark, inspected the cap and rotor, and made sure my battery was at a full charge. It is still a no go. When I turn the key the engine cranks until it seems like it is just about to start then the engine pauses and starts cranking again. Am I right in guessing that my fuel pump, while stil pumping, is not hitting the required 56 PSI to operate the injectors and it is time to replace the pump?
I have the kit to test the line pressure but for some reason I cant see the schrader valve on the fuel line. I know it is on the fuel line near the back of the block but I must be blind because I cant find it.
SPONSORED LINKS
Thursday, January 10th, 2008 AT 4:26 AM
