1999 GMC Sierra Heater fan & 4 wheel high/low shifting
ROB PLANCE
  • 1999 GMC SIERRA
  • V8
  • 4WD
  • 162,000 MILES
The heater defrost fan motor works intermitiately.
Also it appears to quite functioning when the transmission refuses to shift into 4 wheel drive (high or low). The indicator light shows it is trying to shift but never does shift into 4 wheel. The transmission appears to function fine.
Tuesday, December 23rd, 2008 AT 2:43 PM
JEN6238
  • 9 POSTS
First, when my heater worked intermittent it was the plug into the blower motor (remove glove box) a short trip to the junkyard and I even matched the wire colors snip, snip and a little solder.
Second 4wd is usually the ENCODER MOTOR in your situ again junkyard if your inclined. Practice removal at the yard if you need to.
Saturday, January 3rd, 2009 AT 8:55 PM
